Oday 35 Owner Modifications and Upgrades
Lines lead aft on ODay 35
posted 10-07-2008 by Ed Ryan
Lines brought back from the mast are the jib halyard, one of two reefing lines, and the topping lift (not shown here). Also shown is a line (red) for the traveler.
Cockpit - Port bulkhead
Lines from the mast are the main halyard, main sheet, and one of two reefing lines. Also shown is a line (red)for the traveler.
Cockpit - Starboard bulkhead
Lines on port side of mast lead through mast collar blocks and then to line organizer and then aft. Jib halyard, topping lift, and reefing line shown.
Mast collar - port
Lines lead aft from deck organizer to rope clutches.
Deck organizer - port
Lines pass under traveler and through a slot in the coaming on their way to the rope clutch.
Slot in coaming - port
Main halyard and reefing line lead through mast collar blocks to deck organizer. Main sheet lead through turning blocks before leading aft to rope clutch.
Mast collar - starboard
From deck organizer and turning block (main sheet) lines are lead aft to the rope clutches.
Deck organizer - starboard
Main sheet, main halyard and one reefing line pass under traveler and through slot in coaming, leading to rope clutch.
Slot in coaming - starboard
All of the OEM blocks were Garhauer, and the mast collar blocks that are integral to the lines lead aft came from Garhauer. Shown is a newer model of a mast collar block with bushing and nut.
Garhauer mast collar block
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
OdayOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
