Oday 25 Owner Modifications and Upgrades
Oday 25 Mast Raise
posted 10-07-2008 by Rick Leger
See Oday 25 Raise and Lower Mast System
**This simple system using an extension ladder as a crutch and the halyard winch on the mast worked excellent to lower my mast. Excuse the crude drawing but hopefully it helps if you need it. (1-2 people to guide the mast while 1 person eases down the front stay through the halyard winch on the mast). Once the mast is resting on the ladder, you can lower the extension ladder down, then release the mast pin at the base and walk the mast forward, using the ladder to hold the mast as you slide it forward. Be sure to secure the ladder in every direction to keep it stable! **Suggestion only - not responsible if you try it and are unsuccessful.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
OdayOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
