Oday 25 Owner Modifications and Upgrades
Conversion of an OD25 Main Salon to a Queen Size
posted 10-07-2008 by Don Evans
Remove the stock settee backs and replace with upholstered foam on chipboard or plywood. With a hinged leg, or, perhaps screw on table legs, it will be used to fill in the starboard half of the berth, and is supported on its legs and a teak moulding on the settee fronts.
Starboard Settee Back
With both settee backs filling in the middle, and sleeping athwartship, gives over 7 feet of berth. The port settee back is supported on either end by small utility boxs, one I use as a tool box, and the other a trash bin.
Queen Size Berth
The port settee back is layed down supported by the utility boxs at either end. Shown is the forward tool box.
Port Side Tool Box
Supports the aft end of the port settee back. Behind the bin is the removable hatch for accessing the diesel.
Trash Bin
With just the port settee down, this allows access to the head and the V-berth. It is very large as a single sleeping lengthwise, or as a cozy double, probably head to toe.
Port Settee Forms A Large Single or a Cozy Double
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
OdayOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
