Oday 22 Owner Modifications and Upgrades
Port side Fabric Replacement - Oday 22 (1982)
posted 06-20-2011 by A. Brown
I decided to replace the weathered fabric on the port side of my Oday 22. I have uploaded a template for anyone who needs it for their interior refits. Firstly, keep in mind that the fabric used by Oday (at least in my vessel) is expensive to replace and maybe an alternate should be considered if damaged. The fabric was matched at Jo-Ann Fabrics and it cost $39/yard.
Update:
I replaced the fabric with white vinyl with foam backing. I used the same template. This was an easy install less than ten minutes using spray on adhesive. Cabin is much brighter now.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
OdayOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
