Oday 20 Owner Modifications and Upgrades
little cruiser,big fun
posted 09-12-2008 by cash
The Oday 20 has 400 pounds of lead ballast for stability. The boat can float in as little as 14 of water.
Some of the boat specifications are:
overall length 197
waterline length 173
beam 7
draft minimum 14
draft maximum 311
sail area 190***
max. recom. h.p. 15 but I recom h.p.10 to 5 h.p.
mast length 27
mast height** 31
mast weight 42lb
boom length 96
boom weight 10lb
c/b-keel material lead
c/b-keel weight (approx) 400
standard rudder material fiberglass
Seating 6
Sailing displacement 2425 with 4 people at 150 lbs. each
Minimum trailering weight 1825
Complete hull weight only 1750
Safety features: self-bailing cockpit and self-righting
My sources from the Oday cruisers book
if you have questions e-mail at cashman2310 at yahoo.com
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
OdayOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
