Oday Mariner Owner Modifications and Upgrades
1973 Mariner
posted 09-12-2008 by Rod Johnson
The ODay Mariner 2-2 Sailboat (1973) If you love to cruise, but hate being the last one home, then ODay has a Gold Medal boat for you. With the proven hull design of the Rhodes 19 as the basis, ODay has come up with a comfortable cruising boat thats fast and has named it... The Mariner. Shes fast and able and the ladies like her comfort. Foremost in comfort is the 8 1/2 cockpit, which easily seats six adults and has under seat stowage. Below in the lockable cabin are full-size berths for four: Two forward and two quarter berths extending under the cockpit seats. The galley area can be equipped with optional accessories...sink, water pump and tank unit, and offers space for stove and counter work. The Mariner 2 2 also comes with provisions for either a pump out or portable self-contained head. The entire cabin area is well lighted with portlights. Stowage for small and large gear is ample. With these comforts and the Mariners performance, its easy to see why more than 2,550 Mariners are in the water today. Sheets are easily tended without leaving the safety of the cockpit, and the halyards are cleated to the mast. The centerboard is ideal for shoal-draft cruising and easy trailing; youll find the rig is the same. Sails are flexible, however. You can order either a working jib or the larger genoa, which gives improved performance on all points of sail. Whichever way you choose, the Gold Medal Mariners sails are small enough to be easily handled by members of your family. A spinnaker is an option you may want to consider, it makes downwind sailing more fun. Length: 192 Beam: 7 Draft: Centerboard up 10; down 411 Sail area: 185 sq. ft. Along with all of these other features, you will find positive foam flotation for safety, a vinyl guard strip running from bow to stern, and the Mariner exceeds MORC self-righting requirements when the centerboard is in the down position. And, the transom reinforced for secure mounting of a small outboard. No wonder Mariner owners get together to cruise and race as part of the National Associations activities. For class information, contact: Edward Rosenberg, Levittown, NY STANDARD BOAT $2595. Main and Jib $230. The Standard Price includes as STANDARD EQUIPMENT $544. worth of features and equipment as follows: PLEASURE GROUP $190. Value Built-in insulated icebox (45). Storage shelves (30). Tabernacle (mast hinge) (15). All hardware non-corrosive or stainless steel. 2 year warranty. Transom designed for outboard. Kick up rudder (55). Vinyl gunwale guard (351. Mooring and trailing bow eye (10). ACCENT GROUP $122. Value Molded in waterline stripe (201. Varnished Philippine mahogany trim (40). Gold anodized mast and boom (121. All colors molded in. Fiberglass - centerboard trunk cap (201. Two-tone cockpit color (20). Gold racing stripe (10). SAFETY GROUP $125. Value Positive foam flotation (40). Foam filled mast and boom (10). Roller reefing (12). Automatic cockpit drain 1251. Stainless steel rigging with swaged terminals (16). Thru bolted mooring and stern cleats (22). Self-rescuing. Self-bailing cockpit. Non-skid deck and seats. HIGH PERFORMANCE GROUP $107. Value Quick release cam cleats for main and jib sheets (40). Adjustable jib sheet leads (10). Stainless steel wire halyards with Dacron tail (12). Stainless steel turnbuckles (45). Best Dacron running rigging. ODay builds valuable necessary equipment into each boat as standard...for your safety and enjoyment. Compare ODays equipment and construction with any other boat for total value and quality. Prices shown are Suggested Retail. F.O.B. factory.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
OdayOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
